Results 1 to 4 of 4
  1. #1
    Join Date
    Feb 2006
    Posts
    3
    Default Multi-section solid problem
    Attached is a zipped CATIA V5 R14 file of construction curves from which I am trying to
    create a transmission housing. I have spend hours trying to loft the curves using the
    multi-section solid command but to no avail.
    Any help would be greatly appreciated.
    Thanks,
    David Lomshek
    Attached Files Attached Files
  2. #2
    lspieler Guest
    Default
    David I was able to loft in GSD using several lofts instead of just one.The last loft was the transition between the neck and body that seemed to be the area not allowing one complete loft. I then Joined the lofts and created a solid.
    I tried to upload a Zip file with no luck I'm not sure why I could not send it back to you.
    If you post your E-mail i will send it to you. Hope this helps.
    Larry
  3. #3
    Join Date
    Jul 2006
    Posts
    1,437
    Default
    David....
    I was able to make a quick multi-section solid from your B-splines (I use R15). I ignored the control points and had to use a "ratio" coupling option, but it did make a solid. (see attachment)
    I think Larry's method of making a surface is better, because you have more options and more control.
    Looking at a side view, I see there are four linear sections to your shape. To get a "better" solid, I suggest making four mult-section solids by using the first and last B-spline of each section. And then combine them and add fillets
    But I guess it all depends on what you plan to do with the model. I'm guessing this is IGES data?
    Attached Images Attached Images
  4. #4
    lspieler Guest
    Default
    David
    Here is the part file if you need a solid just close Join.1. Had to delete the solid to get the upload.
    Have fun!!!!!!!!
    Larry
Similar Threads
  1. CATIA V5 Multi-section Solid Problem
    By MrAero in forum CATIA Forum
    Last Post: February 10th, 2010, 05:03 AM
  2. error update: multi-sections solid
    By quanghai0986 in forum CATIA Forum
    Last Post: April 12th, 2009, 11:17 PM
  3. Need help on Multi-Section Solid tool
    By vorse in forum CATIA Forum
    Last Post: February 9th, 2009, 07:29 AM
  4. Cross-Section Problem in Model
    By balachandar in forum Pro/ENGINEER Forum
    Last Post: July 31st, 2008, 09:01 AM
  5. Multi-Section Surface with blade sections
    By fowler14m in forum CATIA Forum
    Last Post: May 8th, 2008, 06:46 AM
  • You may not post replies
  • You may not edit your posts
