5 Reasons for Transitioning to CATIA V6
phongnvt
1. Database document management
CATIA V6 connects to the 3DEXPERIENCE platform, and as such enjoys all of the benefits that the industry has come to expect from PDM. Version management, modification rights, release control etc... are all present and configurable to the company’s needs. This means that in addition to all of the other features described below, CATIA users migrating from file-based CATIA V5 to V6 will be able to work much more efficiently. All of the grief associated with managing collaborative working, such as manually copying files, trying to manage revisions and trying not to accidentally overwrite other’s work you have loaded in session, is all dispensed with.
2. Infrastructure changes
Simply put, CATIA V6 works quicker by taking advantage of a computer’s resources far more effectively than V5,reducing the waiting times on rendering, loading large assemblies and performing complicated mathematics. It may sound like a trivial change to some, but this affects virtually every operation CATIA makes, which can amount to a substantial time saving for every user.
The 3DEXPERIENCE platform is designed to be hosted on the web from the ground up. This means that whether you are connecting CATIA to the 3DEXPERIENCE platform through the web or on the company local network, you will be transmitting and receiving data optimised for the current network state. CATIA will also only request the data it needs when opening assemblies, only loading the full data for the assembly’s component parts when requested by the user. This is similar to CATIA V5’s cache mode, except that the lightweight files needed for this process are created by a server process beforehand, speeding up the loading process even further. The web based nature of ENOVIA also makes it easy for users to connect their session to the database, encrypted from anywhere without the need for complex setup on each client machine. This makes collaboration between different sites or businesses convenient.
Note: CATIA V6 remains a ‘client application’, like V5, installed on a user’s PC. CATIA V6 communicates with the 3DEXPERIENCE platform via an internet-compatible connection. Non-CATIA users connect through a web browser.
3. Searching and exploring the structure in 3D
Even with a PDM system managing data, it is often still onerous on the user to fill in a search form for every part or assembly they wish to search for, particularly when using an external program as mentioned before. CATIA V6 however, has an ever-present quick search bar which can be configured to search on any property of the CAD data required (e.g. part number and description). Full and detailed searching is still available should the user wish to construct more elaborate searches.
On top of all of this, the user can also set up lists of favourites and folders to store and organise their own work. Due to the way the database handles the data, designers are free to create any folders or favourites they require without affecting how other users access the data. This is quite unlike using CATIA V5 file based, where moving files into different folders can lead to much frustration, as links between files break as a result of moving and copying them.
All V6 rich client applications have the ability to explore the visual structure of assemblies in a quick lightweight mode, without needing to open the full design data. This allows CAD and non-CAD users alike to view the structure of assemblies from the top levels and find the parts they want without needing a powerful computer able to open the top level assemblies in full design mode.
While other PDM systems are able to do something similar, they often rely on CAD users constantly opening and updating the top level assemblies in order to keep the viewer files up to date. The 3DEXPERIENCE platform that controls the data is able to recognise changes to parts and will then automatically update all of the affected representations, keeping all stakeholders up to date in how the structure really looks. The data stored can be further enhanced by attaching other file types directly to the CAD data (reference tables, exported PDFs, etc.) This documentation is then fully database controlled and is released alongside the CADdata it is attached to.
Finally, it is possible to use the database to visually colour the 3D objects based on various customisable parameters, most notably identifying if objects are released, obsolete or still in work (figure 1).
4. Integrated database control
CATIA V5 has the ability to integrate with various other PDM systems; however this is typically done with a separate program installed ontoCATIA which is used to search for objects and load the required files locally for CATIA to use. Whilst this is functional and certainly an improvement over file-based CATIA, they tend to share a number of limitations with each other, namely:
- The user interface has a line between where the PDM ends and CATIA V5 begins, making for an unintuitive interface which involves swapping between two programs to find, open and save data
- Complex mappings between CATIA V5 properties and database attributes need to be set up in advance, with the need to synchronise these properties with the database. Given that the user has free reign to modify any CATIA property, such mappings are open to abuse by unscrupulous users
- Drawings are considered parents of parts and assemblies, meaning that locating the drawing for a part you already have in session requires you to go searching in the database again
- Multiple revisions of the same part or assembly all must have the same filename, meaning that it is difficult to compare an object with earlier versions, and all but impossible to have one high level assembly with different versions of the same object, since CATIA V5 cannot handle the same filename loaded into session more than once, like most other file-based programs
- Since the CATIA V5 files need to be stored locally, a user could potentially download the files they want and work outside of database control, send uncontrolled copies of drawings or worse, steal the company’s data.
None of these problems are present within the 3DEXPERIENCE platform:
- The user interface in CATIA V6 is the database interface and the properties of CATIA V6 data are the database properties, so no mappings are required
- Multiple revisions of the same object can exist in session without issue
- Drawings are inserted against the parts and products they represent, meaning that it is easy to find and open drawings for the parts and assemblies you have selected or opened
- Finally, while data is still transferred locally to the CAD machines, it is transferred in a way indecipherable to anything other than that particular CATIA V6 session connected to that particular database and permissions to export files in other formats can be controlled per user.
5. Better link management
In file-based operation, a problem invariably faced by any design department is the visibility of links between one CATIA file and the next. These are only visible ‘one way’, i.e. from the files that are using linked copies of the data to the files where that data was originally created. This makes it impossible to interrogate a file and determine what other Parts, Assemblies and Drawings are currently reliant upon it. One person moving the file or modifying some important geometry can unwittingly ruin any other file that relies on the now-modified part. Existing database PDM systems do alleviate this problem to some extent by removing the need for the user to move files around, while also enabling the user to identify if links exist between two objects. V6 goes one step further by allowing the user to identify the exact features being used and where they are used, from any given object. Geometry links, publication links, contextual links, material links and drawing links can all be identified without the need to open the object up fully into session, meaning non-CAD users can see and gain an appreciation for what parts are reliant on what.
