Pipe welding in Catia
eclipse7
Hello everyone! My name is Enrique and I'm new at this forum :)
I'm mechanical engineering and have been working with Catia for a long.
Actually, I have the task of doing a hidraulic piping line representing the welding between the different sections. It is my first time with Weld Design module and got some problems with pipe welding.
I want to do a simple Butt weld with two pipes that are assembly togheter but when select, cant click OK. I have been searching on internet but not too much info.
This is what I have and when try to weld together, nothing. I have tried with the pipes together, a little bit separated...
If someone could help me I would be very glad :)
Hi again. I still have the doubt about how to weld two pipes.
I have been thinking all night and maybe a chamfler in each pipe would help. Here comes the second problem, all pipes have been desgined by shape and after given a thickness. The problem is that that way I can not use chamfer tool in part design, and in shape I dont find any similiar, any way to give chamfer to the pipe that way without having to design it in part design?
I have also tried with two part design pipes with chamfer and nothing.
Has someone ever made something like that?
Thanks in advance!
Hello Enrique,
I wish I could help you with your CATIA problem, but I know nothing about the Weld Design workbench.
I do see a number of tutorials and videos about it when I search the internet - maybe something there will help you figure it out.
I see that you are a student. Does your professor know how to do it? Or maybe the Dassault Academy might help: https://academy.3ds.com/en
Thanks for your answer MrCATIA.
I'm also new at the Weld Design Workbench.
I have seen some tutorials on internet and tried them, everything fine. But no one was with pipes faced together, where the problems cames.
Yes, I have asked some mates but no one have used it.
I will keep trying it.
Thank you again :)
