Results 1 to 4 of 4
    Oct 2006
    5
    Default PowerPoint presentation using Acrobat 3D models
    Hi
    I created a PowerPoint presentation by inserting Acrobat 3D model, the problem is that on a machine with only Adobe Reader 7.0.7 installed it's not possible to view the content!
    What should be done to view the presentation, can anyone give me some insight about it.
    Thanks in advance
    Feb 2006
    323
    Default Acrobat
    I'd suggest downloading a free trial of Acrobat 8.0
    I'm not sure on your issue, but will check out.
    Thanks,
    Camelia Guest
    Hi Carleigh,
    For others to view the PowerPoint with embedded 3D models, you have to convert it to PDF first using the Adobe PDFMaker plug-in that appears on the Adobe toolbar inside PowerPoint.
    Your PowerPoint will be converted to PDF and will preserver your 3D model inside PDF with full interactivity. Now you send the PDF to anyone using just Adobe Reader 7 to view it.
    I entered the thread to help out, but I see that Camelia already did that.
    <a href="http://www.altium.com/">Altium PCB Designer</a>
Similar Threads
  1. 3ds Max -> acrobat 3D pdf - no materials
    By brucebra in forum Acrobat 3D Forum
    Last Post: February 2nd, 2010, 04:21 PM
  2. Video presentation
    By Cesar3d in forum SolidWorks Forum
    Last Post: September 20th, 2008, 08:38 AM
  3. Replies: 0
    Last Post: August 22nd, 2008, 10:55 AM
  4. Acrobat 3D 8 preview
    By folini in forum Acrobat 3D Forum
    Last Post: May 2nd, 2007, 03:41 PM
  5. Acrobat 3d help
    By habbe in forum Acrobat 3D Forum
    Last Post: May 16th, 2006, 12:45 PM
