Results 1 to 3 of 3
  1. #1
    Join Date
    Jul 2006
    Posts
    5
    Default Creating Work Planes at Compound Angles?
    How can I create a compound angle of a work plane in order to drill a hole through a part? Is there a way to put a compound angle on a work plane? I usually put an angle on the work plane and draw the other angle on the part to get the compound. But is this the only way?
    Thanks in advance.
  2. #2
    Join Date
    Jul 2006
    Posts
    26
    Smile
    Create a sketch to extrude, then create a plane at 90 degrees to that, where the top of the part was going to be, on this plane, create a sketch with an angle (on each end), then create a plane using the angled line of the sketch and the first plane that was created and extrude the first sketch FROM/TO using the angled plane.I d0 this for each end and dimensioned the sketch. Now I can drive the part with parameters. Be sure to keep the angled sketch that you draw away from the extruding sketch otherwise you might run into problem.
    Cheers!
  3. #3
    Join Date
    Nov 2006
    Posts
    20
    Default
    There are several ways to create work planes at odd angles, you can sketch an angled line in one plane to the surface of your part then create a work plane on the end of the line by selecting the line, then the end point. You can create an angled plane by selecting a work axis then a work plane & specifying an angle or by selecting an edge & a plane.
Similar Threads
  1. Rotation diretion of work planes?
    By Banigno in forum Inventor Forum
    Last Post: August 6th, 2007, 11:07 PM
  2. User-Defined Work Planes
    By Ariabod in forum Inventor Forum
    Last Post: January 20th, 2007, 09:45 PM
  3. Intersect two planes
    By Azura in forum CATIA Forum
    Last Post: December 14th, 2006, 08:10 AM
  4. Replies: 0
    Last Post: July 12th, 2006, 01:04 PM
  5. Inventor 8 - work planes and axis
    By Perdiem856 in forum Inventor Forum
    Last Post: March 4th, 2006, 11:42 PM
  • You may not post replies
  • You may not edit your posts
