Results 1 to 6 of 6
  1. #1
    Join Date
    Jan 2008
    Posts
    4
    Default Fractional dimensions
    Is there a way to change just a dim to a fraction. I know that you get them all to change, but how do I change individual ones?
    Thanks in advance.
  2. #2
    Join Date
    Nov 2006
    Posts
    20
    Default
    I don't think can get Inventor to show fractions by default but, if it's just the odd 1 or 2 dimensions you can double click the dimension then, in the text tab select 'hide dimension value' & insert any text that you want.
  3. #3
    Join Date
    Jul 2006
    Posts
    29
    Default
    Fractional display is only managed at the style level (i.e. not as an override like precision and tolerance), so you'll likely need to create a new dim style with the desired settings and apply that style to desired dims.
  4. #4
    Join Date
    Feb 2006
    Posts
    3
    Post Changle Individual Dimensions to Fractional
    Right Click on said dimension, new dimension style, and change it to fractional, then it will allow you to change individual dimensions either dicimal or fractional. you can to use both styles in your drawing. Good Luck!!!!
  5. #5
    Join Date
    Mar 2008
    Posts
    2
    Default
    See DIM Style thread...
  6. #6
    Join Date
    Jan 2007
    Posts
    1
    Default Dim. issue
    Simply left click on the dimension so it remains highlighted, left click on the top right drop down(don't know name, see attached screenshot) and left click on the "Default - Fraction (ANSI)" button. This will change a single dimension to fractional.
    Attached Files Attached Files
Similar Threads
  1. Hiding Dimensions
    By Spider-Waffle in forum CATIA Forum
    Last Post: August 14th, 2008, 02:19 PM
  2. Align Dimensions
    By Ariabod in forum Inventor Forum
    Last Post: July 21st, 2008, 10:06 AM
  3. Dimensions not associated
    By cmlucifer in forum AutoCAD Forum
    Last Post: February 15th, 2008, 08:00 AM
  4. No dimensions on drawings
    By broncolane1 in forum SolidWorks Forum
    Last Post: February 9th, 2008, 01:08 PM
  5. How can I edit dimensions?
    By newbie1924 in forum Solid Edge Forum
    Last Post: September 12th, 2006, 09:30 PM
  • You may not post replies
  • You may not edit your posts
