Results 1 to 3 of 3
    Jun 2009
    1
    Exclamation Assembly features not showing in draft
    I've just finished a 3D model of a construction using Solid Edge v20 academic version and now have a problem with the draft drawing:
    The construction is an assembly of parts and sub-assemblies. Moreover, I have added "assembly features", namely a few threaded holes, in some pieces of the assembly. When I create a new construction drawing, I select (check) the checkbox to display "assembly features". However, none of these features are actually displayed in the drawing (draft).
    Is there anything else that needs to be done?
    Or is this a general problem of Solid Edge v20?
    Thank you for you help in advance,
    Jochen
    Oct 2015
    2
    Default i feel (felt) your pain
    I know this post is ancient, but I had so much pain with this issue I just had to post the solution that I bumped into..
    When you have Assembly features there's no way on earth you can get them to show up on drafts, even if the 'show assembly features' box is ticked in the Drawing View properties, and the Assembly features are definitely not suppressed.
    So, the solution is: with the assembly open, click Save As, Save Selected Model, click on the target part with the assembly features, and presto! here you have a copy of the part with the assembly features in it.
    Hope this helps, happy drafting y'all
    Quote Originally Posted by jochen View Post
    Jochen
    Oct 2015
    2
Similar Threads
  1. minimum no of curves fir draft hinges
    By kanishk in forum Pro/ENGINEER Forum
    Last Post: December 14th, 2011, 12:33 AM
  2. Does this SE V20 draft make any sence?
    By jarpol in forum Solid Edge Forum
    Last Post: November 22nd, 2010, 07:49 AM
  3. Draft Entities - Better Way?
    By jusford in forum Pro/ENGINEER Forum
    Last Post: February 1st, 2010, 08:45 AM
  4. Normals not showing in viewport
    By Barney in forum 3D Studio Max Forum
    Last Post: July 10th, 2008, 08:06 AM
  5. Draft from a curved surface on angle
    By Zevel in forum SolidWorks Forum
    Last Post: August 18th, 2006, 09:19 AM
