Results 1 to 3 of 3
  1. #1
    anoyes Guest
    Default Saving model view
    I can not anywhere how to save a view after positioning to a point other the iso. I need to save model to a view and then return to this at a later time. I know Solid Works has this feature, but can not find in Inventor 11 helps...
  2. #2
    Join Date
    Jul 2006
    Posts
    8
    Default
    If you use the Views in Representations in an assembly, you can save different views. If you are just trying to save a view so you can open it up in an .idw and detail the part, then i would just change the baseview when you set it up. If either of these options are what you want to know more about, just ask and i'll help out. I do not know exactly what you want to do, but I hope this helps.
  3. #3
    phil_kerr Guest
    Lightbulb New views
    Read "Isometric model view" in Inventor help. When you save the file, it will retain the new iso view. This will get you where you want to go, I think. Good luck.
Similar Threads
  1. Catia Saving Problem (with V6)
    By sadhath in forum CATIA Forum
    Last Post: February 27th, 2014, 04:48 AM
  2. Creating a 3D model view from 2D drawings
    By rpjd in forum Solid Edge Forum
    Last Post: July 20th, 2010, 02:28 AM
  3. Convert solid model polygon/geometry based model
    By tancs in forum CATIA Forum
    Last Post: March 27th, 2010, 02:23 AM
  4. Saving a Configuration as a new file
    By gmagnicher in forum SolidWorks Forum
    Last Post: February 21st, 2008, 10:51 PM
  5. Saving changes to styles
    By Berke in forum Inventor Forum
    Last Post: March 14th, 2007, 12:53 PM
  • You may not post replies
  • You may not edit your posts
