Results 1 to 1 of 1
  1. #1
    Default Draft from a curved surface on angle
    The attached file shows a design problem that causes me night mares every time we design a package with this type of profile. On straight areas there is no drama however at the "nose" area it very complicated getting a true straight draft surface at 6 deg. This I have done in the past by plotting
    tangent sketches at various points and creating a surface and then blending back to the main body.
    Would love to hear any ideas you may have
    Regards, Trevor (Zevel)
    Attached Files Attached Files
Similar Threads
  1. Modelling Question, Project to double curved surface
    By NICEBIKEMATE in forum Rhino 3D Forum
    Last Post: November 22nd, 2011, 03:27 PM
  2. Does this SE V20 draft make any sence?
    By jarpol in forum Solid Edge Forum
    Last Post: November 22nd, 2010, 07:49 AM
  3. extruding from curved surface help
    By jfdoug in forum SolidWorks Forum
    Last Post: June 22nd, 2010, 08:13 AM
  4. Draft Entities - Better Way?
    By jusford in forum Pro/ENGINEER Forum
    Last Post: February 1st, 2010, 08:45 AM
  5. extruded cut on curved surface?
    By ronimus in forum SolidWorks Forum
    Last Post: December 5th, 2009, 05:55 PM
  • You may not post replies
  • You may not edit your posts
