Hi all, so if I create a simple box and then use offset edge from the solid menu it will work and I can enter a distance.
If I make a cylinder and place it within the box, do boolean subtract to make a hole, then after that the offset edge does not work.
Is there a way to get 'offset edge' working again? Do I need to fix the geometry/mesh since it has a hole in it?
