Results 1 to 5 of 5
    Dec 2015
    4
    Default How to reduce segments in DXF file
    Hello! I am extracting points coordinates (X,Y) from DXF file. The problems is that there are tens of thousands of points extracted, but I need up to few hundred points. How can I reduce the number of points and segments. The files are exported from Eagle (PCB design) and it is not too complex. I can't export new files with smaller amount of points and lines, but I can work with the DXF files using AutoCAD. Thanks a lot!
    Jul 2019
    2
    In my case, there are thousands of pointes extracted. Anyone know how to reduce it, please.
    We always have summer with greatest moments fireboy and watergirl
    Jul 2019
    28
    Can you upload a screenshot or maybe the dxf itself? I have a guess - you have a shtload of points because you use non-circular curves to create the PCB layout, those curves generate a high number of vertexes, try converting those irregular shapes to arcs. You need the points to enter them into a CNC machine? I could try simplifying the dxf for you in catia. Some point extractors (image below) have filters for the curve types - the 3D polylines are the worst. An arc only needs 3 points to be defined
    Hi all,
    I am not sure what program was used but my guess is that it was AutoCad.
  5. #5
    Jul 2019
    28
    without a screenshot or file, we can't help. We need to see what we're dealing with.
