Results 1 to 3 of 3
    Unhappy How to draw a line between these two planes?
    This is the diagram I drew: PBcBCmG.jpg
    I successfully created offset to a plane but failed to draw a line.
    1,647
    There are many methods to draw a line. And there are many positions to place the line.
    To draw a line (like the red line above) centered on the circle and perpendicular to the plane of the circle:
    (you don't need a sketch for this - you can draw directly in space)
    1. use the Point command and draw a point in the center of the circle
    2. use the Line command and draw a line
    - line type: PointDirection
    - point: center point of circle
    - direction: plane of the circle
    - up-to-1: front face of the block
    There are many methods to draw a line. .......... the block
    I can't understand literature. Can you show me by gif format?
Tags for this Thread
