Results 1 to 6 of 6
    Default Why is my slant dimension is not equal to original diagram?
    My diagram: 20.16.JPG (I marked with red colour)
    Original Diagram: 20.16 original diagram.jpg
    1,666
    The top chamfers are wrong because you didn't follow the dimensions in the drawing. You should have dimensioned both chamfers with the 16 x 16 dimensions, and ignore the 32 dimension.
    The 40mm dimension on the drawing is the height of the center gusset.
    Why is my 40mm dimension on the drawing wrong?
    1,666
    Quote Originally Posted by kingston123 View Post
    Look closely at the 3-view drawing in your original post.
    The 40mm dimension (circled in red) does not define the chamfers - it defines the height of the gusset
    The chamfers are dimensioned with the two 16 mm dimensions (circled in blue)
  5. #5
    What is the meaning of gusset? How does it look like?
  6. #6
    1,666
    search result for "definition of gusset"
    The gusset is the orange feature in the picture below. It can also be called a "rib" or "stiffener"
