Results 1 to 3 of 3
    Default Why this line showing up on both faces?
    Desired diagram: 2.jpg
    My diagram:1.JPG (see the marking)
    I applied edge chamfer on top edge (Length 1\length 2) as (10\35)
    1,682
    I'm not sure why those lines show up. Maybe a software bug in CATIA?
    Using Chamfer to taper the front and rear faces is an interesting technique. Chamfers are normally used to eliminate a sharp corner, like a fillet. They normally are short and don't extend the entire length of a face, like you've done. But there's nothing wrong with using a Chamfer for the tapered faces. Maybe it was confused with the slot in the middle?
    You didn't show the tree diagram, so I have no idea what features were used to model what you have so far. And there are many ways to model a part like this.
    But I suggest replacing the Chamfer with a Sketch and use a Pocket to cut-off the faces, like the picture below.
    YES. I applied edge chamfer before applying slot(pocket). Then I didn't get that line.
