Results 1 to 4 of 4
  1. #1
    Default Why this error poping up after completing the sketch?
    I am trying to draw a threaded hex screw.
    Step 1: I successfully placed the point and constructed the helix: 1-1.JPG
    Step 2: I select that point and construct a profile. 1-2.JPG
    Step 3: While exiting the profile, this error pop up: 1-3.JPG
    •   AltAdvertisment
  2. #2
    Join Date
    Jul 2006
    Posts
    1,753
    Default
    I'm not sure I'm following the steps, and without seeing the tree history, I have to guess at what you've done.
    Did you draw the thread profile in Sketch.2 ? Sketch.2 should only be the point that is used to define the helix curve. The thread profile should be drawn in a different sketch.
    In a previous post, you included a link to a video. Go back and watch that video very closely. He goes fast, but all the steps are there.
    •   AltAdvertisment
  3. #3
    Default
    Quote Originally Posted by MrCATIA View Post
    There should be a Grove to cut the threads into shaft of the screw.
    If I choose Grove then what is the use of Slot feature in CATIA software?
    •   AltAdvertisment
  4. #4
    Join Date
    Jul 2006
    Posts
    1,753
    Default
    You are right - the Slot command is used to cut the thread into the shaft, not the Groove command. My mistake - sorry.
    (I edited the post above to remove the erroneous information)
  • You may not post replies
  • You may not edit your posts
