Results 1 to 3 of 3
    Default Increasing Pattern
    Hello everyone,
    Can anyone tell me how can I can create a pattern on a curve with point with increasing distances?
    Meaning: distance between two points, 2 mm , 4mm, 8mm...
    1,751
    In CATIA V5, the Pattern tools only do uniform spacing.
    To space the points on a curve with different distances, you have to make one point at a time and key-in the increasing distances.
    If this is something you do all the time, you could write a CATIA macro to automate the process.
    Thank you!!!
Tags for this Thread
