Catia Generative Structural Analysis Body issue
Oasis
Hello everyone, I am an engineering student, I didn't work a lot with catia so I am messaging you to get some help on a problem I have using the structural analysis module.
Here is my problem, I want to make a simulation on a product I made (it's a mount for an engine test in a wind tunnel). The issue is one of the part of this product contains several bodies, but when it comes to mesh, I can only mesh the "Partbody", not the Body.4, and I don't why.
So I am waiting for advice and suggestions.
Best regards
NB: the Body.4 is the one I selected on the screenshot
If you want to analyze all the bodies as a single part;
In the tree, right-click on a Body.x and choose the ADD option. This will add the Body geometry to the Part Body geometry. Repeat for all the other bodies until everything is added to the Part Body. Now you can create the mesh of the entire mounting bracket.
Thanks for the reply, but the thing is I don't have the ADD option when I right-click on Body.3 (for instance). Capture d’écran (1).jpg
MrCATIA I just found out I had to click "Edit" first, so don't take the previous reply into account
So I created the mesh for the mounting, and the screws. I added a contact constraint between the screws and the mounting bracket with 200N as a tightening force. But I don't understand why CATIA gives me 10^4mm of desplacement in the perpendicular driection of the force exerted on the screws. They are not supposed to move at all towards this directionCapture d’écran (2).jpg
Problem solved
Here is the result. All is grey concerning von Mises, the displacements are displayed as I expected. So, any ideas on how to display the colors for von Mises ?Capture d’écran (4).jpg
Ok, so found out how to display it properly. Still need to hide every thing except the screws cause the highest constraint is there. I'll probably find out myself, so thanks again for the answer, and I'll have to figure out how to close the thread now, should be easier.
