Results 1 to 3 of 3
  1. #1
    Join Date
    Sep 2019
    Posts
    5
    Default measure direction
    new member, I did try searching for this:
    How can I measure between 2 objects & specify the direction I want to measure in? I think so far what I have found was that I'd need to create an axis system, specify that axis, then customize the measurement to display the x,y,z and i'd get my respective measurement.
    I think this will work but this can't be the actual workflow though right?
    •   AltAdvertisment
  2. #2
    Join Date
    Jul 2006
    Posts
    1,691
    Default
    that's how I do it, when I need a measurement in an odd direction.
    •   AltAdvertisment
  3. #3
    Join Date
    Sep 2019
    Posts
    5
    Default
    that's absurd!
    Thanks for the reply
  • You may not post replies
  • You may not edit your posts
