When I started with Catia, I began collecting a series of tutorial PDF and video files. I don't remember in which one of the files I found an instruction that explained about working with 3D spline that could be reformed (in four directions in the space) by a series of points on it.
At the time, by a few of the splines I could create some segments which were reformed by changing the place of the points on the splines (I think this instance is relative to NURBS).
I left Catia for about one year (mostly because of my computer failure). Just tonight I found a PDF that pointed to the operation (without any explanation). As I have forgotten it after the year, I couldn't find the wireframe instance
Please tell me where I can find this type of spline that its shape changes with moving the points on it
I also found this method of reforming the splines in the PDF that was new for me, though I realized how it works, but please tell me how I can use that
If the answer is long and takes you in trouble please introduce some sources or reference to me to refer to.
Thank you
Thank you
