Results 1 to 3 of 3
Thread: Remove geometry from excel
November 15th, 2019, 06:01 PM #1
Junior Member
- Join Date
- Nov 2019
- Posts
- 1
I imported geometry from excel and now I have a beautiful wing profile. I want to trim it but when I try to add a pocket it shows up as a pad since I'm not in the same body as the wing itself. How do I do this a better way?
Advertisment
November 15th, 2019, 09:56 PM #2
Moderator
- Join Date
- Jul 2006
- Posts
- 1,722
I suspect your model is okay, but could you please attach a picture of the specification tree.
If you are using Boolean Operations with your multi-body part, just use an Assemble operation to subtract the body with the Pocket.
Advertisment
November 18th, 2019, 11:18 AM #3
Member
- Join Date
- Jul 2019
- Posts
- 32
Sounds like you have a point cloud or a surface geometry imported from excel? Is your wing profile definitely a solid body? Attach screenshots guys, it's always easier than predicting from a glass orb
Thank you senior, it worked
Some patches are removed unwanted
