Results 1 to 2 of 2
Thread: Datums
  1. #1
    Join Date
    Jan 2009
    Posts
    5
    Default Datums
    How can you rotate datums? I am trying to draw a golf ball using a sphere. I was able to create using curve intersection and the pattern tool. I had to cover the hole sphere. I only need half the image though, so I trimmed using the right plane. I could not trim then create the array because I could not get the datum to align with the centerline, so my array was always going in the wrong direction. If I could rotate the datum, I would have saved myself some work. Can anyone help me with this.
    •   AltAdvertisment
  2. #2
    Join Date
    Aug 2008
    Posts
    3
    Default
    Move entity along direction. select datum you want to rotate then for direction, right click-plane axis ,pick datum, then axis you want to rotate about. zero distance, apprpriate angle. Scott
Similar Threads
  1. Datums on circular features
    By Avital in forum Pro/ENGINEER Forum
    Last Post: July 24th, 2008, 11:31 AM
  2. Show Datums
    By Basil in forum Pro/ENGINEER Forum
    Last Post: May 29th, 2007, 06:35 AM
  • You may not post replies
  • You may not edit your posts
