cutting grooves on cylinder
adi
Hi
I am trying to cut grooves on the outside of a cylinder. A cable will be wound in the groove (R/H). I tried to use the thread function. I set
major diameter: 140
minor: 132
pitch: 8.5
angle: 180
shaft size: 140
method: cut
But the model doesn't show the grooves. It does show the 'thread' in the drafting mode.
Is there another way to cut the grooves ?
Thank you
Re: Cutting grooves on cylinder
Hi Adi,
Question is not clear for me. I request everyone, Pls mention NX Version and explain in detail for better understanding.
Upto my understanding that you have used Thread Command and key in the below Values :
Major diameter: 140
Minor: 132
Pitch: 8.5
Angle: 180
Shaft size: 140
Method: cut
Seems that you have choosen, "Symbolic" option Right ?
Pls enable "Manual" option and enter the below the Values
Major diameter: 140
Minor: 132
Pitch: 8.5
Angle: 180
Method: cut
then pls select the Cylindrical Face , Now Shaft Size Hilights and enter 140 as Shaft size
It works fine and creates a Thread.
Note :
Now you can notice that cylinder face automatically changes to 140 when you enter the value 140 as a Shaft Size Value in Thread Command ( Example : Assume Groove/Hole Dia 200, when you set Shaft Size as 140 in Thread Command, Value in Hole/ Groove dia get updates as mentioned in Thread Coomand)
Pls find the attached Image.
Pls let me know incase you need any clarifications on this.
Thanks,
Srinivas Kumar.T
G4 Solutions
Hyderabad
Hi Strinivas
Thank you, it does cut the thread. But it does not show the thread in the modelling mode. Is this normal ?
There should be grooves on the outside of the face. The thread comes up in drafting though. I am using NX6.
Thank you. I really appreciate it.
Hi
major diameter: 140
minor: 132
pitch: 8.5
angle: 180
shaft size: 140
method: cut
Thank you
You can use groove command to perform your task!
first : creat cylinder (dia 140, height 140)
see picture
adf.ly - shrink your URLs and get paid!
second: make groove (dia 132, width 8.5)
rectangle groove
type parameter
finish!
rgs!
Hi Adi,
Software is working as designed.
If you choose "Symbolic" , It will not create any Threads in Modeling where as it shows Sysmbolic Representation.
Make sure that Hole get updates automatically in Sysmbolic Thread irresepective of Hole Dia
This is a general PRACTICE in an Industry, Beacuse It helps to reduce the File Size and Improves the Performance.
Detailed Thread:
Thread appears in Modeling
Increases the File Size
Prefoemance Degrades etc.
Thanks,
Srinivas Kumar.T
G4 Solutions
G4 Solutions established with a tremendous experience for all Design Applications, Project Execution and Business Consulting for Design Solutions. Specialized in cost effective and customized mechanical design applications in project design, drafting
