Results 1 to 3 of 3
July 7th, 2006, 09:52 AM #1Adorjan Guest
Creating a Menu/ToolBar on CATIA Screen [CAA]
I'm In CATIA Customization. Now i developed one customized tool for CATIA V5. but i don't know , how to create a link in CATIA Screen.
Can any one give a solution to create my own menu or toolbar on CATIA screen.
Advertisment
July 8th, 2006, 10:01 AM #2
Junior Member
- Join Date
- Jun 2006
- Posts
- 2
Re: Creating a Menu/ToolBar on CATIA Screen [CAA]
If you are talking about CAAV5 / C++ API, then refer to « 3D PLM
Architecture / User Interface » in the C++ API documentation.You will
find many use cases on that (large) subject.
What you probably want to know is how to run your own script macro
from a command in a toolbar.
You can do 90% of the job in the "Tools / Customize" Menu where you can
- Create new workbenches (in the « User Workbenches » Tab)
- Insert or create a toolbar in a workbench (in the « Toolbars » Tab)
- Insert a command in a toolbar (in the « Command » Tab)
You will easily find out how to manage the first 2 steps.
Now, to insert YOUR macro, go into the « Command » Tab, where you have
to choose the « Macro » category. The list of your available macros
should appear.
Select the one and drag and drop it in the Toolbar of your choice.
Note that a macro command has no Icon.
To choose an Icon, click on the « Show Properties » Button, then on
the « ... » Button to access the Icon Browser (where you will select
the icon of your choice)
Advertisment
July 18th, 2006, 11:22 PM #3
Junior Member
- Join Date
- Jun 2006
- Posts
- 2
If you want to use your self created Icon:
- You must create 2 Icons.
- A small one : a 16 x 16 bmp file
- A normal one : 24 x 24 bmp file
- Both of them must have the same filename !!!
- If the filename starts with « I_1 », then your icon will be at the top of the list in the Icon Browser (and that's cool).
- You have to store the small one in :
« \Program Files\Dassault
Systemes\B14\intel_a\resources\graphic\icons\small »
- And the « Normal » one in:
Systemes\B14\intel_a\resources\graphic\icons\norma l »
Similar Threads
Creating sections in CATIA
By namrata23gemini in forum CATIA ForumReplies: 4Last Post: March 3rd, 2016, 02:55 AM -
Creating Menu Icons
By pra@ara in forum CATIA ForumReplies: 0Last Post: November 3rd, 2010, 06:29 AM -
Transfer from Express toolbar to Toolbar?
By Apiatan in forum AutoCAD ForumReplies: 1Last Post: September 11th, 2008, 07:59 AM -
Creating button in toolbar
By Baruch in forum 3D Studio Max ForumReplies: 1Last Post: May 29th, 2007, 04:21 AM -
Creation of buttons in toolbar & option in menu
By rajakumarjk in forum CATIA ForumReplies: 0Last Post: August 4th, 2006, 03:08 AM
Thanks that's helpful. I suppose if u want to use it to create a Gear it will be too complicated to be worth it. My idea was to make one and just change the parameters to become other sizes.
Building a curve with an equation
