Results 1 to 7 of 7
    Default converting file from PDF to DWG?
    I am a CAD Learner and I want know that What are the benefits of converting file from PDF to DWG?
    Noah (CAD Learner)
    Sep 2013
    13
    Hi NoahAva ,
    Pdf is really a good format in terms of digital drawing.But often the dwg format is used more in engineering aspect, as pdfs are not easily editable.On the other hand dwg files are easily editable and can used in other software packages than Autocad,like Solidworks etc which really makes it a good format.
    Hope it helps.
    Sep 2014
    13
    My advise would probably be very amateur but then the easiest way i could think of.
    Google yourself a converter, its that easy! i google my file converters all the time and they work perfectly. Its actually convenient cause you wont have to install a software and all, you can convert it straight up so its really simple.
    I suggest though that if you are to convert numerous files then you really have to download and install a software
    Pdf to dwg conversion has innumerable benefits. Unless that is useful for your work. The software converts file in easy steps. Get the detailed benefits of its benefits from Updates and Blogs mentioned below.
  5. #5
    Jan 2018
    2
    Hi Noah, If you have any copy of a CAD drawing in pdf, you can convert it to (.dwg or .dxf) to save your time and to make your drawings very quickly without creating unnecessary stuff which you are already having. Don't go for any online converters, your data might get stolen by hackers. Please use any CAD software which is having inbuilt PDF to DXF or DWG...
    I suggest you, go for below link to download an inbuilt .pdf to .dxf CAD software
    https://actcad.com/download-actcad-i...hIQI2XcP96cFd0
  6. #6
    May 2018
    1
    I tried the PDF in DWG converter similar functionality useful to me in with graphic 2D-drawings that programmers helped me to carry out
    https://www.assignmentexpert.com/pro...cience-project
    Through the utility, I can transfer pdf to dwg, preserving the original quality and even the fonts from the original file. In fact, through PDF in DWG,
    you can open a file created in AutoCAD 2005 and later. This universality is useful especially.
  7. #7
    Hello Community,
    Thanks Emily for your recommendation. In search of the same converting a PDF file to Drawing format, I found ActCAD 2019 Professional having the inbuilt Open PDF to Edit feature. This feature came really handy to me as I can now convert my PDF drawing files to DWG format without the threat of data loss and threat of getting my drawings stolen.
    You can also try the software and take the advantage of Open PDF to Edit Feature.
    Click to Download ActCAD 2019 Professional.
    Thanks and regards,
    Thomas Parker
Similar Threads
  1. Converting from CATIA to .jt
    By lhenrick in forum CATIA Forum
    Last Post: April 22nd, 2015, 02:09 AM
  2. Converting .TCW to .DWG for mac.. help!!!
    By jamesbissland in forum TurboCAD Forum
    Last Post: June 4th, 2012, 01:10 AM
  3. Converting Surfaces
    By MrBlueSkyq in forum Solid Edge Forum
    Last Post: January 21st, 2010, 01:14 AM
  4. Converting Drawing view into Image.
    By Yashwanth in forum SolidWorks Forum
    Last Post: August 31st, 2009, 10:14 PM
  5. Converting ProE into intelicad?
    By baqar in forum Pro/ENGINEER Forum
    Last Post: November 18th, 2008, 09:07 AM
