Results 1 to 10 of 12
Thread: On surface point
March 20th, 2013, 10:58 AM #1
- Join Date
- Aug 2012
- Posts
- 6
On surface point
Hello
In the command point, on surface point type, what is the role of direction option?
I have tested it. The curve on surface between the reference point and the resulted point has the same value as ditance option. But I can't notice to the relation of this curve with the direction. What's wrong?
Advertisment
March 21st, 2013, 06:44 AM #2
Moderator
- Join Date
- Jul 2006
- Posts
- 1,468
The Direction defines which way the offset Distance is measured from the Reference Point. The direction is often an axis (ie X-axis), but can be any straight line.
March 21st, 2013, 12:00 PM #3
- Join Date
- Aug 2012
- Posts
- 6
Thanks.
It is induced if we project the direction on the surface, normal to the plane tangent to the surface at the reference point, the resulted point will be layed down on this curve and the distance will be computed along this curve. Am I right? If so why isn't this true in this example?
(Provided by V5 R19)
Code:http://www.mediafire.com/?gcmhb8373njmlah
Advertisment
March 21st, 2013, 03:42 PM #4
Moderator
- Join Date
- Jul 2006
- Posts
- 1,468
could you attach a picture of your example, please ?
March 21st, 2013, 10:49 PM #5
- Join Date
- Aug 2012
- Posts
- 6
I appreciate your kindly help.
Code:http://upload.tehran98.com/img1/qdd12y57gizuxgj2tlt.jpg http://upload.tehran98.com/img1/vq32f3ydff8sbz2rjtz.jpg http://upload.tehran98.com/img1/oizat5m2wqzl4r38ylo.jpg
Advertisment
March 22nd, 2013, 07:07 AM #6
Moderator
- Join Date
- Jul 2006
- Posts
- 1,468
simple case
(still can't open your attachments, but thanks for sending them)
I've attached a simple example of how I usually use this command. Usually the Reference point already lies on the surface. And the direction is based on an Axis direction or some other line/edge I already have in my model. In my example I am creating a new point on the surface that is .500 inches away from my Reference point in the Y direction.
March 22nd, 2013, 07:22 AM #7
Moderator
- Join Date
- Jul 2006
- Posts
- 1,468
second example
Based on your description, I've created a second example using reference geometry that is NOT on the support surface:
Again, I am creating a Point on the surface that is offset .500 inch away from the Reference point, but in the direction of the line. In this case, CATIA projects the Reference point normal to the surface, and creates the new point based on the projected point. And in the same direction as the line.
According to the online Help file for this:
The COARSE option will offset the Distance in a straight line between the points.
The FINE option will offset the Distance geodesically along the surface.Last edited by MrCATIA; March 22nd, 2013 at 07:28 AM.
March 22nd, 2013, 09:59 AM #8
- Join Date
- Aug 2012
- Posts
- 6
(I checked my above both attachments and personally have no issue. Besides, it's strange I'm not able to see your attached pictures! After I click on the names of them, get the following message:
)asaese, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Anyway, what I meet with my example is not the same as your statements. Step by step:
1. There is a support surface and a point on it. This point is as the reference point.
2. There is also a line parallel an axis (Y-axis for example) that goes through the referece point. This line is as the direction.
3. I create an on surface type point based on the mentioned above and a distance of 100 mm. The location of this resulted point is not meaningful for me. It is not 100 mm away from the reference point along the direction. I don't know how the location is computed?
I upload my example on a cloud space. hope you can download it. (R19)
+Code:https://www.dropbox.com/s/fqxlewpl6lfeyjl/t3st.rar
I'm sure the way CATIA computes the location of the point, is almost the same as computing the location of a Point-Direction type line when a support is defined. If I knew how the projection occurs, all would be solved. Do you know which direction the line is projected in?
Thanks for your care Mr.CATIA.
March 26th, 2013, 08:29 AM #9
Moderator
- Join Date
- Jul 2006
- Posts
- 1,468
March 26th, 2013, 10:50 AM #10
- Join Date
- Aug 2012
- Posts
- 6
Yes, I am trying to know how the program works. I'm just exercising and exactly confused by CATIA.
Thanks that's helpful. I suppose if u want to use it to create a Gear it will be too complicated to be worth it. My idea was to make one and just change the parameters to become other sizes.
Building a curve with an equation
