Hello, can anyone please help and or explain this issue that I am having. I am working with a recent install of CV5 R18 running on Vista 64 bit Home Premium.
When working in a product, If I activate a part and go into part design wb I get an unfamilair error message when I attempt to insert a geometrical set:
“Part1” can’t be selected because it’s inconsistent with aggregation rules
As soon as I close the error message catia creates the geometrical set as normal. However the only visible geometry on the screen is what ever in work object is active, everything else is not visible or selectable from the tree.
For instance, if I create a copy of a solid and paste into a different geo set I can only see one at a time (which geo set is the in work object). Or say I am trying to create an intersection in GSD work bench, if I have a surface in one geo set and CAN NOT select a curve in the different geo set by selecting from the tree.
I have never seen anything like this before in CV5 R15 - R17. If anyone can give me any ideas as to what the problem is it will be grealty appreciatted.
Thanks.
Thanks.
