Broken Leader Lines???
Jonster
Does anyone know how to do broken leader (dimension) lines within NX6 drafting?
I've seen it done so know it's possible - just can't find out how!!!:confused:
Cheers,
Jon
Jonster
Encase anyone else would find this useful I found out elsewhere how to do this ...
Insert > symbol > user defined symbol > utility directory (on top) > pick one of the "gaps" (8th from top of list) > attach to leader ....
it may take a few trys to get it correct, after the gap is on there you can change the length of it in the menu, so it really doesn't matter which of the three gaps you initially pick.
If you want to remove the gap from the leader line you will have to remove that leader, then add it back in there, in the dimension menu
