Chris Grenke
Hi folks!
Cheating is getting out of hand. Is there an easy way to check who created a part in catia v5?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: this_feature_currently_requires_accessing_site_using_safari
I don't think V5 includes that information (and I didn't see it in the file properties). If you are using a PLM system, like Enovia, you do have the history there.
Unless you are giving your students step-by-step instructions for how to model a part, I doubt if any two files would have the exact same:
file size
tree structure
sketch geometry and sketch constraints
If the CATIA files are in the same folder, you could easily list them and sort by filesize to identify which ones are suspect. Interrogating the actual models would prove one was copied from the other, but not which one was copied.
