Conical Spring
Dem.Pet
Hello everybody,
This is my first post here (new member).
Am trying to simulate the response of a conical spring (non-linear). I have created the spring in CATIA and am trying to run the analysis in ANSYS. Though the results aren't what they are supposed to be (am always getting a constant k). On a conical spring there should be an increasing of the k factor (stiffness) for every coil that becomes inactive (image attached).
My question here is if there is a way to do that analysis in CATIA. So, I want to simulate the way the conical spring behaves on certain loads. The compression of the spring, when a coil contacts another coil etc. At the end i would be able to get the exact Load/Displacement curve.
An idea is to create the spring using multiple half-coils and connect them together and then select each coil as a contact element in Ansys. I don't really know how to do that or if it will work.
If you have any ideas or a solution to that it will be of major help.
Thanks in advance!!
