connection
jugoslav
Catia V5R20 SP0 x64
Windows 7 Ultimate x64
is it possible to insert or connect scatch from part 1 to part 2 and when scatch in part is changed or saome dimension is changed the scatch in part 2 will be changed exactly the same as in scatch in part 1.
Sure. Just use COPY on the sketch in Part 1, and then use PASTE SPECIAL and choose the RESULT WITH LINK option. The pasted sketch in Part 2 will now be linked, so if you do change the sketch in Part 1, it will change in Part 2 when updated.
I suggest you use Publication when creating links like this. Just Publish the sketch first, and then copy the Published sketch.
