Converting Surfaces
MrBlueSkyq
I'm new to SolidEdge and this forum,
actually I'm not even the typical CAD user :)
I'm a programmer currently writing a model viewer for models designed in SolidEdge using openGL.
Problem is the models are built by surfaces.
My format of choice (*.XGL) exports empty data when I try..
I thought about turning the surfaces to a solid form, but SE seems to get stuck when I do so (if I pick multiple surfaces and use "Thickness" it displays a message box of "Unsucessful operation" without any additional data).
Picking the surfaces one by one seems like a crazy way to fix this..
Does anybody know:
* How to convert surfaces to solid?
* How to export surfaces in XGL using SE?
* How to export surfaces data in another "easy-to-read" format such as XGL or OBJ (which requires a quite costy plugin)?
I'm using UGS SolidEdge V18..
Thanks in advance!
andrewyipko
Hello there,
I hope to offer a satisfactory answer to your questions here.
Surfaces are of zero thickness, and you'll have to assign a positive thickness value to it in order to make it a solid.
You can export surfaces to XGL format in SE/ST2.
You may consider exporting to JT format, since it an ISO certified 3D visualization format.
Hope this helps. :)
