Cutting a solid for injected casing with a complex parting line
paddlestroke
I am having some difficulities with the following :
How to cut a solid object in two parts in order to make a plastic injected casing when the cutting line is complex?
Typically for a game controller such as gamecube controller or N64 controller. See for example this picture this N64 controller : http://nfgcontrols.com/grafx/N64-pad-side.jpg
Would you use "cavity and core" tools? Parting line seems adaptated.
Reflect line give good results on the organic shape. But then I can't figure out what to do to separate the solid in 2 parts, then shell both parts.
Also is there a way to make borders automatically such that the casing close correctly? Borders such as this picture :
Because with this complex parting line it makes it complicated. Can we use the parting line and make a parallel line of it then extrude it?
Please include a picture of the part you're asking about.
Is your goal to have two parts of the casing? (top half and bottom half)
I have not used CATIA's Mold Tooling Design product, so I can't comment on the "cavity and core" methods. Maybe someone else with experience can help? (I did see several videos and tutorials when I searched the internet)
paddlestroke
Yes I need the 2 parts of the casing.
I succeeded to cut the solid like this :
1 - finishing the parting line into an assembled curve
2 - create new geometrical set
3 - cutting the volume with surface cutting tool.
4 - fill the inner surface by adding some lines
5 - Fill the closed surface into a new solid
6 - Shell with 1mm thickness. But it does not work with more than 1 mm (2 or 3mm) thickness for an unknow reason...
I tried to modify the inner surface by changing the added lines but no luck so far.
I think it's the surface at the reflect line part. I would like to try to add some lines to cut the surface into small pieces but I can't separate the reflect line in small pieces.
Any idea why I can't shell over 1mm thickness?
Error reads in french :
1.La valeur de décalage courante donne une surface localement dégénérée : la pièce ne peut pas être construite.
2.Sommet non reconstruit après décalage, la face
et la courbe incidentes ne se coupant plus.
Your steps seem to be OK.
I did a google translate on the error message, but even in English it wasn't clear what the problem was.
Most often the error with shell is the thickness is greater than the radius of curvature somewhere on the surface. But your surfaces seem to be good, based on the pictures you've attached.
2 suggestions on how I would do it (although I don't think my method is any better than yours):
1. Divide the model into the two pieces; the top and the base. (this will simplify the geometry)
2. Instead of a Shell; I would Extract a surface from the solid piece, Offset the surface, and then Split the solid to remove the inside.
