Disconnecting two profiles
Mans
Member
When I draw two profiles (for example a rectangular and circle) both are connected to each other and when I want to pad the circle, the rectangular is padded along with circle as well. How I can disconnect two profiles in part design as just the one that I select is padded?
Thank you
Most people would draw two sketches; one for the rectangle and another for the circle. Then each sketch can be used for different pads.
One Sketch for Multiple Features
Some people like to draw everything in one sketch. They use the Sub-Elements option to make different features (pads, pockets, ribs, etc.) from a single sketch. Personally, I find this method very difficult to work with, but thought it might be something you might want to do with your rectangle-circle sketch.
You can find more information about this method in the CATIA Online Documention, or click here
Part Design and scroll down to the Using the Sub-elements of a Sketch section.
Mans
Member
Although I couldn't open "part design" address that you hinted but I found "sub-elements" order in another website and it was very useful thing for me.
Thank you :)
I just had a chance to try the 1-sketch method:
a. make a sketch with several profiles (rectangles, circles, etc.)
b. add a Pad; instead of selecting sketch,
- b1. right-click in profile box and select Go To Profile Definition
- b2. select more profiles if required
- b3. select OK
c. specify Pad length and verify direction
d. OK
repeat steps b,c,d for other Pad/Pocket features using other profiles in the same sketch
