in electrial part design workbench
how to define a connector?
there are 7 types of connectors!
The different types available are:
Single Insert Connector: male or female connector
Stud: connector used to secure bundle segments
External Splice: connector used to secure bundle segments from different geometrical bundles
Terminal Strip: connector with electrical termination strips
Terminal Block: connector used to secure bundle segments, each bundle segment wire being connected to a termination
Multi Insert Connector: connector mounting single insert connectors
Internal Splice: connector used between wires belonging to the same bundle segment.
I am confused! I don't know what type of connector can be defined as a stud and what type of connector can be defined as a single insert connector!
So, I hope somebody can help me! Thank you very much!
