feature help
RAL
I am trying to attach a pouring spout (as in a milk jug etc.) to a cylinder body can anyone suggest a good way to do this? I want the spout to be a smooth blend with the cylinder body
any help much appreciated.
JonC_TEDCF
Hello RAL,
I'm having some difficulty visualizing your situation. Posting a picture or a file would help a lot.
If I'm understanding correctly, you have a cylinder body and would like to add a pouring spout onto the cylinder. If this is the case, one solution is to create a sketch of the spout near the top edge of the cylinder. Next, use the Revolved Boss/Base command to attach the spout to the cylinder. Then use the Shell command and select the top face to create the hole.
Jon C
TEDCF Publishing
SolidWorks & Autodesk Inventor Training Tutorials by TEDCF
qiulien
amiation!
i think amiation play a essential role in the daily life! but i do know so much about the amiation's knowledge! so bless you have a good luck! have a good luck to save the problems ! thank you !
