Thats great. But what about if the surfaces are not connected together.First, Join all the surfaces together into a single surface. Then Measure the Join to get the total surface area.
You can Join all the surfaces even if they are not connected. All you have to do is make sure the "check connexity" option is not selected in the join definition.Thats great. But what about if the surfaces are not connected together.
For example I want to measure sum of two areas that are on the completely oposite site of the part? Any solution also for that?
