shekar.mech
There Are 2500 Horizontal Lines (2d X-y Plane) In My Drawing ,i Need Y-coordinate Of Starting Point Of Each Line And Length Of Each Line In A Data File, That Can Be Exported To A C-program. Thank You In Advance.
After select all lines that you want length and starting point you write in a command line " LI " than enter, after that will pop a window with a that numbers, continue to press enter to see all numbers.There Are 2500 Horizontal Lines (2d X-y Plane) In My Drawing ,i Need Y-coordinate Of Starting Point Of Each Line And Length Of Each Line In A Data File, That Can Be Exported To A C-program. Thank You In Advance.
