How to pattern a sketch
Kanter
Everything is in the tittle, I can't create a pattern directly in a sketch :confused:, I'd like to duplicate a shape to design the profile of a tooth !
I select the shape, I click on pattern (circular), I draw the circle but nothing happens....An idea ?
KrisKasprzak
If you are in 2D draft, pick the element first, then the pattern commands become active.
if you are in 3D part sketching, the pattern commands are used to creating a pattern sketch for later creating 3D feature patterns--it as you have found doens't pattern 2d elements. Patterning 2d elements can be done with the rotate and move command (there is an option within those commands that duplicate element--hence patterns can be created.
Hope this helps.
Kris
