I need help for drawing an inducer
MiladAsiaban
Hi guys,Im new in solidworks and i wanna to create an inducer model at it,are there anyone to help me please?
I attached a figure that represent the general geometry of an inducer.
1. I'm sure someone here can help you. What have you modeled so far? Do you have any dimensions indicating the size of your part?
2. You say you are new at CATIA, but you asked your question in the SolidWorks forum; which CAD system are you using?
Unfortunately, I had written catia instead of solidworks.I have dimensions from an article and i attached it for you.
Best regards
MiladView attachment 2020
You can start by creating a revolve for the center shaft.
Then create a helix out of three sections: a tapered one that has an increasing diameter, one with a constant diameter and a tapered one with decreasing diameter.
Create the shape of the section that revolves around the shaft. Could be a rectangle.
Create a sweep that uses the spiral as a guide and the rectangle as a profile.
That should do the trick :)
Thank you for your answer peter
