Importing Blender into Catia
Monstrobolaxa
There are quite a lot of graphics designers using Blender and they do some very realistic and accurate models.
I'm interested in reverse engineering the surface geometry from a Blender file.
Does anyone know a way of importing Blender files into Catia?
I will let some people suggest a few ideas and I'll post later (tomorrow) the process I've found!
I apologize for the delay in replying.
So the only way to export a Blender file into Catia appears to be by exporting it as a .stl file and then reverse engineering the surfaces.
Now when opening the file it comes up as a mesh file, which is painful to reverse engineer.
What I've done in the past was use one of the two following options (using the Digitized workbench):
- extract cross-sections in the 3 axis and then close all the surfaces and clean up the ones that need cleaning up.
- use the 3D line tool to draw the main lines and then close the surfaces.
Now that was all fine with a relatively simple geometry (10k nodes)....but now I'm working on a very complex geometry which has over 500k nodes.
Any ideas how to reverse engineer the surfaces from the .stl file?
How is it done on a point cloud file?
