Is my center points for 37.5 angle arcs are correct?
kingston123
In desired diagram, we can see three arcs with angle 37.5 each but center point for three arcs are not given properly in this sketch. I took center points like this I construct the arc and trim the arc according to desired diagram. So did I done correctly?
My Diagram: base 80 how.JPG
Desired Diagram:desired.jpg
What you have done so far is good.
Don't forget to add the 163 height dimension. I don't think the 138 dimension is needed, but you can add it also
But you're still not done yet. The arcs should be tangent to each other.
The sketch will be correct when the lines and arcs become green in color, indicating everything is fully defined.
