Limit dimension range in sketch
Filo90
is it possible to limit a curve dimension (example a line) between two values, so that it cannot phisically move outside these parameters? I'd need this to use it as a end stroke for an element in a sketch animation (using the animate constraint)......
If you link the sketch constraint to a Parameter, you can set a Range with MAX (SUP) and MIN (INF). See instructions in the attached picture
Let us know if it works with the Animate Constraint.
