Linear light
jackjames
Hi everybody, I have a problem with v-ray renders. Everytime I use a linear light, appears a white rectangle in the render image. It is from the light but i don't know how to eliminate it, I can't also rotate it .. Can you help me?
sjaeger
I only use Maxwell for Rhino, and Vray for C4D so I can't give a definite answer - but the behaviour should be similar. It seems like Vray is converting the Rhino light object into geometry with a luminous material applied. There should be something that lets you define render properties for each object, that allows you to define the object as invisible for cameras but still "visible" for GI. Have a look under object properties.
