Hi, I'm trying to create a series of 4 lofts, and not quite sure where I'm going wrong.
The base is a square hole from an extruded cut on a solid. I've made a sketch plane parallel to this square cut, and a sketch on this plane with 4 splines not connected to each other. Each side of the square needs a loft to one of the splines (sort of like a square flower). I've also got guide curves extending from the corners of the square to the the ends of the splines.
I can do the first loft with no problem, but I can't do all four in one loft because I get error messages (loft intersecting itself). If I do one loft, then try to do a second in a separate operation, the sketches and the guide curves have been incorporated into the first one, and can no longer be selected.
I have the following questions
1. Is there some way to fix this problem, or do I need a separate sketch for each loft?
2. If I have to create a separate sketch for each loft, then is there some way to just copy the sections without redrawing them?
3. On a side note, if you make a 2D sketch, then realise you need to draw in 3D, is there some way to change the type without redrawing?
I'm using solidworks 2008, and really appreciate any help you can offer.
