Match Surface
Stephan
Hey Rhinofans,
I've got a little/big problem with the Rhino match srf tool. I try to get G2 connection at the surface A B and C. I firts built surface A and match this with C to get a nice connection there, then I tryed to build surface B and match it with a. Now every time I try to blend it with C (tryed diffrent numbers of degrees and options) it always destrys the G2 connection to surface A. Rhino is not able to connect the 3 surfaces A,B and C with G2. I tryed "Multimatching", but no G2 connection also.
Kostenloser Bilder Upload Service - Gratis Bilder hochladen / uploaden ohne Anmeldung
Thanks for the help, I am at the end of hope.
Greetings Stephan
PS.: I dont want spans in my surfaces and they have to be as simple as possible. I tryed the same thing in Autodesk Alias and there it worked...
sjaeger
Hey Stephan,
it's been a while since you posted that question... (seemingly the subscription to this forum doesn't work)
Anyway, I would suggest a different approach:
1. Create a "Sweep 2 Rails" surface, using the long edges of surface A as rails and the edges of surface B and A as profiles with G2 continuity. or:
2. First, create surfaces B and then surface A using "Surface Network" with G2 continuity.
The second approach could produce more isocurves than desired so I would vote for #1.
Cheers, Stefan
