Memory Error from Cosmos FloWorks
JasonBoyer
Hey folks,
I'm doing some CFD work with Cosmos FloWorks. I can run simple problems without any issues, but when trying larger, computationally intensive operations, FloWorks generates a memory allocation error after about an hour's worth of calculations.
The actual error:
"Not enough memory to continue the calculation. Failed to allocate requested continuous memory block of 1048576 (1.00MB)"
I've gotten this error on two separate occasions, each time about 1.25GB of memory were in use (total). This is on a quad-core intel system with 4GB of memory, so I'm guessing the issue is a software configuration problem..
Any and all thoughts are greatly appreciated. Thanks!
dbrewer
memory
Hey folks,
The actual error:
If you are using Windows xp you may be limited to 3 gig of available memory even though you have 4 gigs installed.
Floworks require a contiguous block of memory. If you have breaks you are further limited in the size of problem that can be solved.
You may try exiting solid works, then restart and begin the calculation. It works sometimes.
