morphing text using curve to curve
moneypit
having trouble morphing my text I created in sketch environment. I need it go around basically like a circle.
smd
morph curve to curve
I havent had a problem with that morph and use it quite a bit. If your text is sitting above the desired curve, make sure the curve you're morphing from is centered in the text and not under it. Also play with the bend/translate control to see the difference.Also set your influence high enough. Hope this helps .Scott
