Dear all,
I would like to know if somebody could give me some tips about how to move a mechanism 2d using parameters and formulas in catia ( see attachment ).
The idea is to move this mechanism through max and min X direction as well as using rotation angles.
Thank you in advance
Add all the Assembly Contraints to all the parts in the assembly. Use Angle and Offset Constraints whenever you have parts that rotate/move relative to their linked part. Set the values of the Angle and Offset constraints to the Parameters.
Editing the Parameters should re-position all the parts within the assembly mechanism. You will probably get an error message once you reach the limits.
