Moving parts
rpjd
Having an issue with moving parts. Previously when moving a part on an axis, only the part I selected moved. Now when I select a part, a blue ball with XYZ directional arrows appears on the parts edge. Now not only does the selected part move, but everything pivots around the blue ball. How can I prevent this additional pivoting movement?
Solid DNA
rpjd
Can you tell us what function you use?
CAD-user
My guess is that the function that you used is Rotate which is located on the Main toolbar. This function actually rotates the entire view of the assembly.
If you want to move part, the Move Part function is located at Assembly Command toolbar.
