Multi-section solid - problem with closing points
Lmecano
Hello all,
I'm trying to design a wing but I have a problem with the following feature : multi-sectional solid. When I try to create a solid with 2 sketches, the closing points are well placed but not their arrows ! It results the feature can't generate the solid, of course. I also tried with the coupling function, it's better but there are still some problems.
Do you have an idea how to change the closing point direction ? I precise that when I click on the arrow, the direction is updated but not in the good direction.
The problem :
The CADpart generated with CatiaV5R20,
http://www.filedropper.com/wingprofil
Thank you
Sometimes the direction arrows look like they are pointing in different directions,but they really are not. The arrows will either point in a clockwise or counter-clockwise direction.
If both arrows are the same and the Closing Points are aligned, the Multi-Section Solid should not be twisted.
Lmecano
You're right about the arrows, thanks !
However, I still had a tangential problem with my curves. I solved it by draw my wing in small steps : Leading edge/Trailing edge/ Skin/ Beam/ etc...
Thank you for your help !
